9802 Drive Letter access - sbRIO Support
Dear All
there is a shipped example with labVIEW that mounts and unmounts an SD drive using 9802 named "NI 9802 RT Access" as shown below
randomly it can write a text file with the text i need , and most of the times it give me a connection error , and that the connection to target is lost ...
I'm using sbRIO 9612 and 9642 , and cSeries 9802 module
NI-RIO 3.4
LabVIEW 2009
Please advice as this is an essential part in our project
Thanks in advance
Eng. Mohammed Ashraf
Certified LabVIEW Associated Developer
InnoVision Systems Founder, RF Test Development Engineer
www.ivsystems-eg.com
(3,574 Views)
Mohammed,
   Could you give me some more details on the behavior of the issue? How are you connected to the sbRIO? A crossover cable or is it on a busy network? What do you mean it randomly writes what you need it to? Under what circumstances does it write and under what circumstances does it not?
Regards from Texas,
Ben J.
(3,558 Views)
