Hai all,
   i am using a cRio 9024 controller and i have a 9853 CAN module i am conducting a loop back test using a Single ended termination cable, i am running CAN basic .lvprj example once i am running i am getting following error.
Error 65540 occurred at an unidentified location
Possible reason(s):
CompactRIO: (Hex 0x10004) The I/O Resource is not in communication mode. You must start communication mode before you can perform this operation.
Is it possible to test the module using single ended termination cable cable? all settings are default baud rate=500kbps, auto start=enble, listen only=disable.
thanks
Message 1 of 1
(5,905 Views)
