AT-MIO-16E-2 card whith Real-Time Windows Target 1.0
"Hello,
I am working with the AT-MIO-16E-2 card and I need to use it with Real-Time Windows Target 1.0 for a control apliance.
I have already installed NI-DAQ 6.9.3, and the I/O card is working propperly. But the point is that the Real-Time Windows Target do not recognise the card,in spite of having the AT-MIO-16E-2 driver.
So I would like to know which are the steps I need to do to make it work propperly.
Thanks...
Cristian
(4,075 Views)
Real-Time Windows Target 1.0 is not supported through the NI-DAQ driver and therefore you can not access this card using NI-DAQ. To program the card in Real-Time Windows Target 1.0 you would need to write your own driver accessing the register on the board directly. Information on this type of programming can be found in the Measurement Hardware DDK.
Christian L
Systems Engineer - MH DDK/LV RT/LV FPGA
NI Consulting Services
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(4,075 Views)
