Abort Execution button no longer interrupts "wait (ms)" is that normal?
Well... as for the error, I posted the sample code in the first post.  Thats what shows the bug in the priority execution for LabVIEW RT.
In my code, I do sometimes have timed loops inside a timed loop....  I try to avoid it, after editing the code to remove all the Wait (ms) I used to have, I've now got timed sequences inside a timed loop.
The bug shows up weather you are inside of an internal loop or not I think....  but using a timed sequence setup I've removed all the Wait (ms) blocks.
If I use a timed sequence  in the Test code I posted above the ABORT VI button works fine.
This code works fine for example.
Message 11 of 11
(885 Views)
