Add new targt - no devices found
Starting development on a SB RIo 9605. Having problems setting the project up. Add new target produces "no devices found".
(5,612 Views)
I'm running LabVIEW 2012 (32-bit) on Windows7 64-bit. I can ping the 9605 and I have used MAX to download softwware to it. I am installing LV2014 (which is actually  LV2013) to see if that solves the problem.
(5,596 Views)
And I have all wireless IP connections turned off.
(5,595 Views)
Accepted by topic author Gary_MavSysInc
Problem resolved. I installed LV2014 (which is actually LV2013 Feb - that's not confusing). So  a new target became visiable - SB RIO Embedded. I can now build the project file with the sbRIO9605 target, build a FPGA file and run it. So I'm good.
(5,588 Views)
