Thanks, dude! I got it. I'll make a doc
@nanocyte wrote:
You can use the IO but not with the convenient RMC project interface. You have to use the socketed clip interface and explicitly allow each IO.
The other solution (the one I implemented) is to write your own UART driver instead of using the CLIP. There's an example over here: https://forums.ni.com/t5/LabVIEW-Robotics-Documents/RS-232-Interface-Reference-Example-for-LabVIEW-F...
on it so in future there won't be any problem for the beginners. 🙂
