Adding a IC-3110 to an LV 2018 project
We are trying to create a real-time industrial controller target for a 3110 in LabView 2018. We could do this in 2015, where we found a top-level entry "Real-Time Industrial Controller (NI 3100/3110)" and also a folder "Real-Time Industrial Controller" containing several items starting with IC-3120 and ending IC-3173.
LabView 2018 cannot see this outer entry, only the ones in the folder.
Is the 3110 not supported by LabView 2018, or is there some trick to get it to show up?
(2,331 Views)
Hello LukeASomers,
I apologize it has been some time since you posted your question. Apparently, LabVIEW 2015 was the last version supported on NI Real-Time Hypervisor controllers, as the IC 3110 RT (PharLap).
Moving forward, I recommend you check out the new Industrial Controllers with Linux RT, and the latest driver; as well as the PXI platform.
All the best,
(2,254 Views)
