Adding a WSN 3212 Node to a WSN 9792 Gateway in NI-MAX
Hi all,
I'm having trouble adding WSN 3212 Nodes to my WSN 9792 Gateway in NI-MAX. I've been following the instructions in NI 9792 WSN Real-Time Gateway Getting Started Guide - National Instruments. On page 9 it says:
To add a WSN node to a gateway, complete the following:
1. Expand NI-9792, expand Devices and Interfaces, and then select WSN.
2. Click Add Node.
3. In the Add Node dialog box:
    a. Select the Type.
    b. Enter the NI WSN-32xx device serial number, which is listed on the sticker on the underside of the device, and an ID Number (number between 1 and 50).
4. Click Done if you are done adding nodes. If you want to add other nodes, click Add Another.
"Devices and Interfaces" is not appearing under NI-9792 for me. Does anyone know what I may be doing wrong or an alternative method of adding nodes to the gateway? Thanks for the help!
(2,475 Views)
Hi colleague
Just to make sure, following the previous steps adding the gateway, did you face any issue?. Did you configure the gateway as specified?.
Additionally, this may be related to the software, could you please mention the NI-MAX version you are using and the NI-WSN driver version.
I will be looking after this forum.
(2,418 Views)
