Analog data acquisition using NI 5761
Hi, I have been trying to acquire analog data using NI 5761. I have followed the instructions in the NI 5761- Getting Started example as described in the manual of the 5761. But when giving a sinewave generated directly from an AWG, the examples shows the following error:
status code : -61017, Source: Open FPGA VI reference in NI 5761 - getting started PXIe-796XR (Host).vi
I am using the 5761 with an FPGA module PXIe-7966R. I have attached the screenshot of the error.
Any help would be deeply appreciated. Thanks.
Anindya
University of Minnesota
(5,672 Views)
Hi Anindya,
I've also got this error sometimes and in my case was because I had different
bitfiles asigned, on one hand, inside the "Build Specifications" and, on the other
hand on the "Open a fpga a reference" vi inside the host vi.
My suggestion is to compile/build again and then ensure than the resulting compilation
bitfile is the same in the two cases.
Jordi
(5,654 Views)
Hi Jordi,
Thanks for the help. The error is gone now.
Anindya
(5,633 Views)
