Application for carry out tests on my pcb
Hi!
I create my PCB containing some dynamical systems and I would like to use LabVIEW to do system identification.
So far I've done fpga VI which generates sine wave signal and sends it to AO. In the second while loop  signal from AI is sending to FIFO.
Then I would like to specify frequency and amplitude on my host vi and read amplitude and phase from analog input (now I try to do int for genereted signal to check if it does work, because I use simulation mode), because I would like to create Bode plots to build mathematical models for my systems. So far I did something attached below, but it doesnt work at all...
Please give me any suggestions. What is wrong with my code?
Edit:
Ok. Probably I know one of my mistakes. It is that I haven't put my host1.vi on RT system I did it because I have a problem that I don't have available any function when I try to create VI under RT.
Message 1 of 1
(2,617 Views)
