Are there any other methods than DMA FIFO and FPGA Referenced Connector Blocks to Tx data from the target to the host???
Basically, I am having issues getting a DMA FIFO based transfer method to compile.  For some reason, I can only use two of the three FIFO's at any given time or I get a compilation error.
If I use a connector block transfer method, there is too much information to process within the SCTL and it generates a timing error in compilation.
I have already disabled non-necessary functions in the FPGA in an attempt to get this to work one way or the other...
Any input is appreciated.  Thanks!
(3,401 Views)
Hello which hardware are you using and which versions of the software? Also, what is the reason for failure given by the compiler?
Anna K.
(3,384 Views)
LabVIEW 8.5, PXI 7813R, & the reason for failures can be seen here
(3,380 Views)
