04-15-2014 10:10 AM
I'm designing a Real-time application on a NI cRIO-9022, using the Watchdog Agent toolkit made by IMS Center.
While loading my VI on the CompactRIO, I get the following error message:
Deploying SoundVib_Resampling.lvlib:oa_CIC Interpolation Filter.viSoundVib_Resampling.lvlib:oa_CIC Interpolation Filter.vi loaded with errors on the target and was closed. LabVIEW: Failed to load shared library sndvib.*:OatCICInterpolatorByMovH:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
I found that when I place the "Basic Feature Extraction" VI inside a "Diagram Disable Structure", the deployment is successful, So the problem comes from this VI.
The error message tells me to install a library on the cRIO but I don't know where to find it.
Thanks for you Help,
David
Solved! Go to Solution.
04-16-2014 04:39 AM
Hello David,
You probably didn't install the driver on the CRIO. I don't know which driver your VI is using, and you should get in touch with IMS Center for this information (or whoever gave you this VI).
04-16-2014 06:58 AM
Thank you Benoit,
Installing the "sound and vibrations" driver on the cRIO solved the problem ![]()
