Best DAQ setup for taking timestamps on TTL level pulse signals
Dear all,
I have a device that outputs TTL level pulse signals and I would like to be able to timestamp each falling and rising edge of these signals. That is, I want to take a timestamp each time the signal exceeds a certain trigger level (e.g. 2 V) and similarly each time the signal goes below the same trigger level. I consider that the smallest width a pulse could have is around 50 – 100 us (microseconds) and the largest around 10 ms. The resolution that I want to have is a maximum of 1 us (the lower, the better) with ideally the same level of measurement precision.
One of the main questions I’ve got here is whether it’s best to consider a DAQ system (I have the NI USB-6221 DAQ device available) or an oscilloscope (I have the Tektronix TDS2012B and the Rigol MSO4024 scopes available).
From what I understand, the benefit of using the DAQ device is that I can take a timestamp only when a trigger condition occurs by using a timer. Considering the fact that the NI 6221 has a 32-bit 80 MHz timer, this gives me a resolution of around 12.5 ns, which is perfectly adequate (I have no idea about the precision levels though). The thing that I don’t know though is if I need to read each acquired timestamp sample on-the-fly (are the timestamp stored to any sort of buffer memory?). If that’s the case, I guess I am limited by the interface the DAQ uses (in this case, USB2).
Now, if I were to use a scope, I don’t know if it’s possible to achieve the same result. I know that SignalExpress allows you to measure the period of a signal, but what I really want is to measure the (absolute) time I get a signal edge. Also, this set-up seems to have some limitations as SignalExpress really seems to take a while to perform an acquisition (using the Tektronix scope) for a very small number of samples (e.g. it takes ~ 18 seconds to perform the acquisition of 100 periods of 1 ms).
Please also bear in mind that I would try to avoid using LabView (unless you’re willing to really help me here ;), as I am not really experienced on this and I would prefer to use Matlab instead.
Any help or suggestion will be much appreciated.
Many thanks,
Ioannis
(6,067 Views)
Just to specify that the device outputs periodic TTL level pulse signals (with each signal having a positive and a negative lalf of theoretically equal length).
Also, I want to specify that with SignalExpress I measure the “positive width” and the “negative width” of the signal and not its period.
(6,053 Views)
I replied here, but given that the signal is TTL and you are only interested in transition times I would use the counter on the DAQ card to timestamp the signal in terms of the 50 ppm 80 MHz timebase.
Best Regards,
John Passiak
(5,995 Views)
