CPU usage monitoring with DSM when cRIO is in FPGA mode
I used to program cRIO application in Scan Engine mode, monitoring CPU usage with DSM is straightforward. I like to keep eyes on the CPU and memory usage during development.
Recently, I started to use more FPGA for my applications, mostly of them are in hybrid mode (scan engine + FPGA on cRIO-9047). I upgraded from LV2016 to LV 2018 recently too. I noticed that, I can monitor the CPU via DSM when I am in debugging mode. But after I compiled and deployed the codes on cRIO, I can't monitor the CPU in DSM anymore, all shows static value or '0'.
I tried to get the CPU usage from the LabVIEW functions, the same thing happened. The CPU usage was obtained and updating on the HMI during debugging. However, after I deployed the cRIO code, the CPU usage became 0 and wasn't updating.
Please help.
TexasRock
(3,314 Views)
Hi TexasRock,
Were you getting the same behavior before upgrading to LabVIEW 2018?
Are you deploying an RT exe?
-sarahmo
(3,285 Views)
Have you installed System State Publisher?
CPU and Memory Usage Not Visible in NI Distributed System Manager
Certified LabVIEW Developer
GCentral
(3,278 Views)
Hi Emboar,
I had the System State Publisher installed. I can view CPU & Memory when I ran under Scan Engine mode.
This happened when I programmed with FPGA, compiled the RT target and deployed.
I barely used FPGA before upgrading to LV2018. not sure if it is introduced by LV2018.
TR
(3,271 Views)
Sorry, i don't know whether the problem is LV 2018 specific.
You didn't see the behavior on LV 2016? Umm....
GCentral
(3,250 Views)
