CRIO 9022 Software Installation
Anybody can help for installation of NI 9022 software through MAX
I am connecting NI cRIO-9022 with an Ethernet.
I have been facing a timeout error and saying that whether it is online or not, as far as im concern its connected in safe mode as it still has no software in it.
Please refer to the attached file.
(5,284 Views)
Accepted by topic author Maybach
It is most likely a networking detail.
It looks like you have a link local address on your cRIO (169.x.x.x) which means you should still have your computer setup to use DHCP. If you have a static IP on your computer, try switching back to "Automatically obtain an IP address"
If that does not work, I would try setting a static IP address on both the cRIO and your PC to install the software. Once you get the cRIO software installed, you can switch everything back to DHCP.
Find detailed instructions here:
http://www.ni.com/gettingstarted/setuphardware/compactrio/firstuse.htm
Kurt
(5,268 Views)
