CRIO
hi
i have labview 2010, and i'm beginner.
i want to start with examples "how to develop in CompactRIO"
i select Help >> Find Examples. Then i select Hardware Input and Output ..but i didn't find CompactRIO!!
Message 1 of 10
(6,159 Views)
i will develop first then i will choose the appropriate CRIO
Message 2 of 10
(6,158 Views)
Hey moonm,
You've probably seen the reply to your post here by legolas, but I wanted to re-iterate that in order for the cRIO examples to show up in the example finder, and have the functionality I believe you're looking for, you'll need to install the LabVIEW Real-Time Module, LabVIEW FPGA Module, and NI-RIO driver. To ensure compatibility of your software, make sure you follow this table:
NI-RIO and LabVIEW Version Compatibility
https://www.ni.com/en/support/documentation/compatibility/17/ni-rio-and-labview-version-compatibilit...
Hope this helps!
--Ryan S.
Message 3 of 10
(6,143 Views)
Merci..
Now i have LV 2010
can u give me some link to download the LabVIEW Real-Time Module, LabVIEW FPGA Module, and NI-RIO driver
Message 4 of 10
(6,127 Views)
Hey moonm,
You can find the 2010 versions of the LabVIEW Real-Time and FPGA Modules here:
Services Resource Center
http://digital.ni.com/src.nsf/display?ReadForm&lookup=LabVIEW&view=suproduct&node=node=203014_us
And NI-RIO here:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du/q/RIO/
Make sure you select the correct versions based on if you're using LabVIEW 2010 or LabVIEW 2010 SP1. Hope this helps!
--Ryan S.
Message 5 of 10
(6,114 Views)
hey
thx for these links
so i should only install these three : the LabVIEW Real-Time Module, LabVIEW FPGA Module and NI-RIO driver ?
Message 6 of 10
(6,102 Views)
Hey moonm,
Depending on your specific application you may need additional toolkits or modules. However, for simply getting started with your cRIO and using the basic examples you should only need the Real-Time and FPGA Modules and the NI-RIO driver. For proper order of installation install LabVIEW, then the modules, then the RIO driver. Hope this helps!
--Ryan S.
Message 7 of 10
(6,085 Views)
any can help me to give a link to install the real time module for labview2011 and also link to install the crio driver..i just use the evaluation labview..i use a crio-9022..tq
Message 8 of 10
(6,044 Views)
Hey apeace,
For LabVIEW 2011, you'll need Real-Time 2011 and NI-RIO 4.0 which are linked below:
Real-Time 2011:
https://lumen.ni.com/nicif/us/evaltlktembdes/content.xhtml
NI-RIO 4.0:
https://www.ni.com/en/support/downloads/drivers/download.ni-rio--legacy-.html#326645
However, if you downloaded the evaluation version of LabVIEW then it's possible you're actually using LabVIEW 2011 SP1 in which case you'll need different links. So, double check your version and if it's LabVIEW 2011 SP1 then let me know. Otherwise, use the above links. Hope this helps!
--Ryan S.
Message 9 of 10
(6,030 Views)
ok ..thank you.
Message 10 of 10
(6,028 Views)
