Can I Use a USB-to-Serial Adapter on a CompactRIO?
I believe I was told that the CompactRIO’s USB port does not implement a standard USB interface; therefore can not work with all USB peripherals. At present time it can only work with hard drive and some flash drives.  Is this still a valid statement?  Because I really wanted to use the CompactRIO’s USB port with a USB serial interface such as your NI USB-232/4.  Is this possible?  Note I am aware of the CompactRIO Serial Interface modules.  I really would like to use the USB port if possible.
 Thanks in advance for any information you can provide Fro
(5,692 Views)
Fro,
As you noted the USB port on the cRIO controller can only be used to access USB memory devices, like a memory stick or harddrive. It can not be used to access other devices with or without the USB to serial converter.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(5,672 Views)
Is there a plan to incorporate into the VXworks or Pharlap code the drivers to allow anything other than memory devices on the cRIO controller?
Fro
(5,668 Views)
Hi Fro,
I wanted to bring to your attention the RS-232 port that is on the controller as well.  Is there a particular reason you would like to use the USB port for communcation over the RS-232 port or serial modules?
Kristen H.
(5,651 Views)
Fro
This is something we are investigating, but there are no definite plans when this feature might be added.
authored by
Christian L, CLA
NI - Austin, TX
(5,648 Views)
Kristen wanted to know why I do not wish to use the RS-232 port on the controller or use C series serial modules.  Well I will need at a minimum of two and a maximum of eight serial ports.  I already have USB to serial devices and I do not have any RS232 C series serial modules, I only have RS422 C series serial modules.  I was hoping I could just plug the USB to serial devices I have already into the cRIO controller, that way no further purchasing is necessary.
Fro
(5,637 Views)
