Can I connect two NI 9233 systems to one computer to acquire vibration data?
Hi, I was wondering if I could connect two NI cRIO 9233 systems to the same computer using USB ports and use Labview 8.5 to collect vibration data.
(3,020 Views)
The best solution is to use the 9172 compact DAQ chassis for both the 9233 to reside in.  http://www.ni.com/dataacquisition/compactdaq/
you can use two of the USB-9233 in the same computer, however the ADCs between the two modules will not be synchronized
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,019 Views)
