Can I invoke RTDLL funcitons from RT VI running in RTX subsystem.
Hi, I'm new to LabVIEW and Real-Time module for RTX.
     I have a PCI-7813R and want to use it in a real-time control system running in RTX subsystem. I need to access PCI-7813R hardware in my RTSS application, I know It's NOT possible to write a RTX driver for it without hardware register-level information from NI, but can I call RIO driver for RTX directly from my rtss application?
     If I can't call RIO driver, I think I have to use LabVIEW and Real-Time module for RTX, and port my RTSS application code to RTDLL, after that, I can use a RT VI to invoke my RTDLL code when PCI-7813R respond to external interruption.
    Is it possible to invoke RTDLL functions from RT VI?
thanx!
(3,392 Views)
It is not easy to develope applications with LV RT for RTX. If possible, use LV RT for ETS instead.  LabVIEW Real-Time supports Call Library Functions for linking external code, including DLLs. However, the LabVIEW Real-Time Operating System only supports a subset of the Win32 API. We do not offer LabVIEW RT support for applications that call external code. For more information, please see the following Knowledge Base:
Can I Use a Third-Party Device with LabVIEW Real-Time (RT)?
I am not sure I have understood your question. If I did misunderstand, please be free to let me know.
Cheng Yang
(3,387 Views)
