Can I use an external reference clock for cRIO?
We have an application where multiple high-speed clocks cause radiation interference.
Is there a way to provide an external reference clock for the 40 MHz cRIO clock?
Is there a way to synchronize a 9144's (expansion chassis) clock to the cRIO controller clock?  I understand EtherCAT does it's own synchronization - I'm talking about synchronizing the 'base' 40 MHz clock.
Steve
(5,757 Views)
Hi maherhome,
Which cRIO are you using? Unfortunately, there isn't a way to export/import clocks like the FlexRIO line: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6OeSAK&l=en-US
We do offer a module which you can use to synchronize https://www.ni.com/en-us/shop/model/ni-9469.html the chassis, but the FPGA clock's will not be. What modules are you looking to synchronize? The clocks should never be more than ~25ns apart.
DylanC
(5,740 Views)
@DylanC wrote:
Hi maherhome,
9082
Steve
DylanC
(5,736 Views)
