Can I use system config api to determine if a RIO is online?
I'm trying to find all the systems that are online. Here's what I came up with:
Unfortunately, I'm noticing that if the RIO is recently turned off, it will still return "Connected - Running" even though I should be getting a system "only if online", I have "force property refresh" true and the user guide says "To determine if a Real-Time target is online, use the System Property Node to return the System Status property." Is there a good way to get if a unit is  online?
As a side note the timeouts seem like they are mostly ignored, Find Time is 7 seconds, Open Time is 3 seconds when they should be closer to 1000.
(3,063 Views)
yes I did something similar with the system config APIs to what you did and encountered the exact same problems. I think a better less complicated solution is to make your cRIOs send out a UDP message every few seconds or so. UDP messages get "broadcast" over the network and do not expect a reply. Then you can listen for UDP messages and use the information in the UDP packet to connect.
(3,019 Views)
I'd prefer it didn't rely on my stuff and could work with a formatted system. Maybe I can hit a web server? I was also hoping I could get NI to fix or clarify what "if online" and "force refresh", "status", or "timeout" really mean because none of them are working as I would expect.
(3,014 Views)
well if you have all the cRIO IP addresses as static you could just do a windows (or linux) ping command via the system exec to each known address. But if you want them to be able to be dynamic IP address yeah there really isn't a good built in solution that I know of. I am fairly convinced system config VIs are bugged.
(3,009 Views)
