Can NI-9403 use DMA-scoped fifos?
I've been trying to implement DMA-Scoped FIFOs using cRIO-9014 embedded controller, 8-slot backplane, and an NI-9403 DIO module with no luck.  Does the NI-9403 support DMA-Scoped FIFOs?  I can only use/see targeted-scoped FIFOs.  I don't even see a selection for 'FIFO'->write in the invoke method function under FPGA toolkit.  Is there a way to impement DMA FIFOs?
Todd Moore
(3,537 Views)
DMA FIFOs and the 9403 are not related. You should just be able to create a FIFO for your target. If you right-click on the FPGA Target, are you not able to navigate to New -> FIFO?  After doing tha, you should be able to change the option to Target to Host - DMA or Host to Target - DMA.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,534 Views)
Thanks for the quick response. I think I have found the problem. I was originally pointing to the bitfile in the 'open FPGA vi reference' properties, but I hadn't done a re-compile since I made changes to the FIFOs.  I pointed to the actual vi instead and now I can manage the DMA fifos.  I expect that I will need to re-compile the fpga before I can point at the bitfile again.  Does this sound right?
Thanks again for your great help.
Todd Moore
(3,522 Views)
That does sound right. Try it and if it doesn't work out, be sure to post back.
Adnan Zafar
(3,508 Views)
