Can i generate PWM output from digital out of my PCI 7041 RT DAQ card?
I want to generate 4 PWMs using my PCI7041 card. I do have only 2 analog outputs and 2 counters to output my signal that's why I want to use digital out of my card for PWM. How can I do that? If there is any example then please let me guide that way.
(3,084 Views)
Hello rajen,
There is a good link to PWM in LabVIEW using counters here.
As for using analog output, you will need to be able to continuously update your output waveform. I've attached a program that demonstrates this. Hope this info is helpful.
-Alan A.
(3,071 Views)
