Can not install LabView 2018 Real-Time Module with NI-DAQmx 19.0
My laptop has installed window 10 Enterprise and I have to install NI-DAQmx 19.0 to make MAX work without problem.
Now, I am going to use NI cRIO-9035 but I can not install LabView 2018 Real-Time Module because the LabView says I have NI-DAQmx 18.5 or newer installed in my computer.
What solutions I can have? Install a LabView 2019 Real-Time Module? I currently use LabView 2018 SP1 in my computer.
Any help will be appreciated.
Jay
(2,367 Views)
LabVIEW 2018 RT is compatible with DAQmx 19.0, but you have to install LabVIEW Real-Time 2018 before DAQmx. Try uninstalling DAQmx 19.0 and then installing LabVIEW 2018 and LabVIEW Real-Time 2018.
(2,318 Views)
