Can't access CompactFlash on cFP-2120 after upgrading from RT 8.5.1 to 10.0.1
Hi !
I am facing the following problem: I cannot acces the CompactFlash of my cFP-2120 after
upgrading from RT 8.5.1 to RT 2010.0.1, using Fieldpoint 6.0.8 in both cases.
Is there a compatibility issue between cFP-2120 and RT versions >8.5.1 ?
I completely format the cFP-2120 (Format Disk command in MAX). The CF is a Kingston 4GB (FAT32) and worked fine in RT 8.5.1 I checked also 2 other CF...
It is not an issue of FTP access, since even my LV code now returns an error when accessing 😧
Any idea of what's going wrong ?
Dimitri
Message 1 of 1
(3,912 Views)
