Can't change serial port settings on cRIO 9072 controller.
I am attempting to connect a device to the RS-232 serial port on a cRIO 9072 controller.  MAX sees the port just fine, and it is apparently working properly, but does not allow me to change the port settings.  The device I am attempting to connect operates at a different baud rate than the (apparent) default for the cRIO port.  Help would be greatly appreciated.
(3,617 Views)
Hi Obxetec,
I believe you have to configure the port in software when you establish the connection. The VISA config serial port VI has a baud rate input that will configure the port. You should call this VI prior to calling the read and write VIs.
Let me know if this helped.
Sappster
(3,602 Views)
yes, that was the issue
(3,600 Views)
