Can't connect to sbrio 9627 from project.
In MAX my sbrio-9627 is visible as connected and running but I cannot run my application on it from LabVIEW.  When I try to run a vi to control the attenuator and phase shifter on the PCB connected to sbrio there is no response. No error code showed.
The IP address of sbrio is static as I specified.
Message 1 of 1
(2,276 Views)
