Can't see connected cRIO-9002 in MAX
I can't see the connected cRIO-module in MAX when I try to configure it for the first time. I've tried to connect to cRIO through a hub and with a crossover-cable. Neither helps
I've hardcoded a IP-address on the computer and disabled the firewall(and anti-virus). But that didn't help. Any suggestions?
I'm using Windows XP and SP2.
Regards Ulf N
(3,643 Views)
Have you installed the NI-RIO driver CD? You should have received a CD, NI-RIO for Reconfigurable Embedded Systems, with your cRIO-9002.
Chris
(3,631 Views)
Chris
NI-RIO CD wasn't included in the package(for some unknown reason), so I had to download it from NI-web (300-400MB). I'm using version 1.2.
(3,623 Views)
The problem is solved. NI-RIO 1.2 from NI-web didn't include drivers for CRIO. Should have read the comment....
//Ulf
(3,621 Views)
