Cannot Open a Datasocket ref. in a built application (LV 8.6.1)
I have observed that from my project I can run a vi that opens a DataSocket Reference to a NSV with the following URL:
\\192.168.0.2\Remote\'Remote Command'
When I built an exe and run on my cRIO then I get an error 56 timeout in the DS Open.  I have verified that the library containing
this variable is deployed by using the Distributed System Manager and it does appear in the remote target under the correct process.
Just for kicks I have undeployed and redeployed but no difference.
Any Ideas?
(3,557 Views)
BTW, the IP address in the URL is the IP address of the cRIO and the NSV's are hosted on this same cRIO.
(3,556 Views)
solution was posted in this duplicate thread
Misha
(3,533 Views)
