Cannot access sbRIO 9642 analog inputs
I'm trying to access the analog inputs in ModA, but I get the following error.  Any thoughts?
(5,633 Views)
what "following error"?
(5,629 Views)
(5,608 Views)
Hi vyas,
Are you using hybrid scan engine with some modules in FPGA mode and others in scan? Or pure scan mode?  Have you deployed your chassis settings to the Single-Board RIO device?  Another customer had a similar issue documented here, and they resolved their issue by reloading software onto their device.  It was suspected they had an invalid software configuration that caused that error.
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(5,591 Views)
