Channel configuration for sbRIO is disabled
Using LV2018, CompactRIO 2018, etc
Trying to follow instructions I found here:
https://forums.ni.com/t5/Real-Time-Measurement-and/Configuring-Differential-Ports/td-p/2564517
also this guide implies the IO is configurable from the project:
http://zone.ni.com/reference/en-XX/help/373197L-01/sbriohelp/sbrio_9627/
Is this expected?
(3,187 Views)
Try to reinstall RIO device drivers
CLD Using LabVIEW since 2013
(3,164 Views)
I fired up a fresh Win10 virtual machine and installed everything this time trying CRIO 18.1 and I'm getting the same thing. The terminal mode and voltage range can't be configured.
(3,154 Views)
Accepted by topic author nanocyte
I worked this through the support channels. This issue has been assigned CAR 713728
(3,078 Views)
I think it would be fair to mark your comment as the solution to this forum post.
(3,059 Views)
