Chassis Temperature reading on cRIO-9054
I reading Chassis Temperature sensor value on cRIO-9054 and getting "140...145" in I16 variable. Just curious - which unit used here? Also if Fahrenheit, then 140F means around  60C and seems to be too high for me, but his device is not so hot definitively.
(2,115 Views)
Accepted by topic author Andrey_Dmitriev
You can refer to the shipping example at
<LabVIEW>\examples\CompactRIO\Chassis Specific\RIO Chassis Temperature Monitor\RIO Chassis Temperature Monitor.vi
https://tmesystems.net/
(2,083 Views)
Thank you very much! It works. By the way - in LabVIEW 2023 this example is located in "C:\Program Files\NI\LVAddons\crio\1\examples\CompactRIO\Chassis Specific\RIO Chassis Temperature Monitor\" Folder.
(2,068 Views)
