Communication between LabVIEW for myRIO and a mySQL remote DB
As part of a project, we would like to communicate between LabVIEW installed on an NI myRIO-1900 embedded target and a mySQL database installed on a remote server. Is it possible and to what extent?
Although this is not very sensible given the limited resources of myRIO, we could also consider installing and activating a mySQL database server on the myRIO embedded map provided that it can be accessed from a (or more) remote mySQL client (s). Is it possible and to what extent?
I thank you for your feedback,
(3,131 Views)
In myrio, Linux is running so, I guess general operation can be performed like this.
Connect to a MySQL database remotely
You can run shell commands on the device.
Running Shell Commands and Custom Applications in Linux Real-Time OS from LabVIEW
Certified LabVIEW Developer
GCentral
(3,108 Views)
You could use TCP to connect to the mySQL database. Something like this?
https://forums.ni.com/t5/Example-Program-Drafts/Native-LabVIEW-TCP-IP-Connector-for-mySQL-Database/t...
(3,071 Views)
Thanks for your proposition.
I will try soon and I will keep you informed of my tests.
(3,068 Views)
Thank you very much "nanocyte" for this link.
I will read this with great attention.
(3,067 Views)
