Compact Rio NI - 9035 chassis wires
Hello guys,
This is my first time to deal with Compact rio, i'm using Crio NI-9035, i actually didn't find connection wires in its package, to use them connecting crio to the power supply and connecting the power supply to the utility power. Is it true that the package doesn't include these wires or am i missing something ?
if i would use my own wires, does anyone recommend certain type of wires and connections ?
is it also very important to connect the ground terminal of crio  ?
(2,056 Views)
Hi A_Ahmed,
I found the NI cRIO-9035 Getting Started Guide online that has some information regarding package contents - it looks like the kit comes with the device and the Power Connector, as well as a cable and drivers.
This manual also has information regarding connecting the device to power and corresponding wiring diagrams that can hopefully provide some insight.
Here is the link to the Getting Started Guide: http://www.ni.com/pdf/manuals/376935c.pdf
Andrea W.
ELP Engineer
(2,015 Views)
