Compatible multiplexer
Dear All,
I am using the NI's “USB-6356, X Series Data Acquisition: 1.25 MS/s/ch, 8 AI, 24 DIO, 2 AO” device for my Ph.D. project at the Ghent University, laboratory of ...
As you know, this device has two analog outputs and 8 analog input channels. Since at least 8 outputs and 32 input channels are needed for my project, it seems that I have to use an analog multiplexer to increase the number of output and input channels.
Therefore, I would like to ask you to recommend a compatible analog multiplexer for extending both analog input and output channels?
Also, I would appreciate it if you have any other suggestions.
Thanks in advance
Message 1 of 1
(1,898 Views)
