Conductivity measurement
I need to measure the conductivity of a fluid via two metal pins we have.
As we have cRIO systems it would be nice to have a module for in this cRIO (i also want to steer some actuators with this system) that can measure this.
Any idea's how to perform this measurement or where i can find already available information? (i could not find it yet)
Thank you in advance,
(3,385 Views)
If a measurement of DC resistance is OK, this module can measure resistance. Conductivity would be 1/resistance.
https://www.ni.com/docs/en-US/bundle/ni-9219-specs/page/specs.html
If you need an changing signal to avoid capacitive effects, I don't know of any modules where you can measure EC directly. You might be able to generate your stimulus and measure current over a sense resistor with something like this:
https://www.ni.com/en-us/shop/model/ni-9381.html
Otherwise, you'll have to find an off the shelf probe/conditioner that can output SPI,I2C, or a voltage.
(3,357 Views)
Thank you for you reply.
Unfortunately i cannot use the DC resistance for measurement.
It seems that i need to extract the values from dedicated PCB's we use in our product. I still need to dig into that PCB to find the right signal.
(3,304 Views)
