02-05-2014 07:42 AM
I have no problem to connect to the cRIO via MAX in the network environment of my company. I would also like to work at home.
How can I connect from Home into the network environment\intranet of my company to the cRIO having a given IP there.
Is there a way using SSH , putty.exe or plink.exe?
Do I need a VPN tunnel?
02-06-2014 06:53 AM
I suggest using VPN, since it is more secure and more common to set up.
The only alternative i could think of would be to set up Port forwarding.
Usually IT department wont agree to do this.
I hope this helps
Best Regards!
Moritz Mayer
02-06-2014 09:40 AM - edited 02-06-2014 09:40 AM
If I ask the IT- administrator, he tells me that there is only a nxclient to access the computer.
He does not know how I cann access the cRIO.
Casn you tell me more exactly how to proceed.
If I have a VPN tunnel, I will see the cRIO in my network environment?
Is it all or something else to think of. Can Plink.exe help me? (I don't know what it is for in fact...)
Thommy7571
