Connect flexible microprobe to NI 9213
Can someone provide me with instructions on how to connect the IT-24P ultra fine flexible microprobe (https://physitemp.com/flexible-implantable-probes_p167) to the NI 9213 spring type thermocouple module.
Daipayan
(2,057 Views)
dsarkar,
From the picture on that link, it looks like the probe has some kind of connector on the end. Do you know if it is a Mini-TC type connector? If so, NI sells thermocouple modules with a Mini-TC terminal block. If you want to use the 9213 with the spring terminal, I would assume you could cut off the connector, strip back the insulation, and connect the wires to the module. That is assuming that there isn't any circuitry within the connector, which would be weird for a thermocouple, but might be worth checking.
-Jordan
(2,024 Views)
