Connect the two straight-line moves without losing the speed between them
Softmotion function block pallete
in my VI, i am using 2 straight line functions from soft motion function block.
here is the thing,
Everytime the first straight line is executed, at the end, the speed will decelerate to 0 then it will go up as the 2nd straight line is being executed.
Is it posible to connect the two straight line without losing the speed between them...??
thank you!!
Message 1 of 1
(3,287 Views)
