Connected - Safe Mode (Software Error)
List of items:
2012 LabVIEW CDs
Compactrio  cRIO-9073
windows 7 home premium 64bit
1.I have installed a full LabVIEW 2012 with all the drivers.
2.Installed compactrio drivers from the CD.
3.Updated and patched urgent and critical items.
4.Configured and downloaded full drivers into compactrio.
Fianlly, Measurement & Automation Explorer shows the rio is connected in safe mode but with software error.
Attached are all the screen shots that I have taken. Could anyone please help?
(7,249 Views)
It's probably just a broken dependency or something like that.
Recommended Solution:
- Format the controller from MAX (don't sweat formatting RT controllers, it's done all the time)
- Only install the recommended software set (RIO 12.0)
- Confirm that works properly
- Add software components as needed from MAX
If you have trouble with it, a favorite of mine is to look at the console output.  On the 9073, you can either attached a serial cable to the serial port and flip the console out switch (if you search there's a KB on Console Output) or view the console output through the web interface (you'll have to have the web configuration and monitoring software installed first).
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(7,217 Views)
