Convert NI example 9870_Serial_Read_Write_lv9.zip to Labview 8.6 please??
Hi All, i'm a novice looking for someone who might save this NI example 'http://zone.ni.com/devzone/cda/epd/p/id/6366' as Labview 8.6 so that I can view it?
Thanks in advance !!
Le Fonz
(3,516 Views)
Sorry myfriend, could you check your link please. It seems to be producing an error. If you can upload the actual example code to this forum, I would be happy to save the example back to 8.6.
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(3,507 Views)
Apologises, I should of tested the link. Please find the files attached.
Le Fonz
(3,501 Views)
Hey La Fonz,
This should work for you!
Best wishes,
Rich Roberts
(3,491 Views)
