Custom control data type FIFO serialize
 I have some trouble in using target scoped fifos.
I use NI FlexRIO 7962 and Active technologies AT1212 DAC board to implement a waveform generator.
The waveform samples are loaded to the DRAM.My application then reads data from the DRAM using a target scoped FIFO. Both the DRAM and the FIFO are custom control data type with 14 samples of 9 bit FXP. The DRAM read occurs at 100 MHz.
From this parallel 14 samples (@ 100 MHz), I need to generate 8 parallel ouptuts for my DAC interface (@156.25 MHz)
How do I match these two rates?
It would be great if somebody could suggest ways to solve this.
Sowmini
Message 1 of 1
(5,538 Views)
