DAQ in real time
How to link labview with my DAQ in real time experiment?
(5,865 Views)
Hello fhahmed2,
Welcome on NI forum!
Can you tell us more about what you're doing?
Which kind of board are you using? PCI or PXI board can be use on PC or PXI Controller on which you can run  an RT OS. If you are using USB hardware... You'll have some issues, cause USB is clearly a None-RT bus.
Have a good day,
Flo
(5,784 Views)
Hello Flo,
I'm using Data acquisition system "OMEGA OMB-DAQ 3000" I'm doing some signal processing so i need to link my DAQ with the labview to do online analysis in real time!
yes it is USB hardware..
any help or seggestion please?
Many thanks..
(5,779 Views)
First of all, I just want to make sure we agree on what Real-Time means (no offense 😉 ).
Being RT means that you can garantee that you will be able to do something in a known amount of time with a known jitter.
A usual case is Input=>Do something=>Ouput; more info on RT here.
It does not necessarily means "fast". What is your sampling rate?
Since you are speaking about analysing and not controlling, I'm wondering if you really need an RTOS (or maybe you just want to get rid of Windows for reliability purpose 😉 )
Flo
(5,766 Views)
Hi Flo,
yes i want to do controlling. the analysis is the pre step of controlling.. the sampling rate 1024 sample/sec..
any support help please..
(5,750 Views)
help me please, how can i conect my omb daq3000 with labview?
(3,340 Views)
