DAQ problem reading data
I just instaled the PCI board together with the CA-1000
Connector Accessory Encloser. The test panel works, so I know that the device is installed. But when I connect a signal to the port on the CA-1000, I don't see
the signal appearing on the test panel display. I just
see a signal that is constant,
with a little variation.
By the way, I also have the PCI-GPIB card installed.
Thanks! Matt
(3,120 Views)
Chuck;
The problem there is most likely due to a bad connection somewhere.
My suggestion to you is to cross check the connection you made with the Users Manual of the CA-1000 and DAQ board to confirm you done everything accordinly.
If that is not the case, the CA-1000 is probably damaged.
Regards
Filipe A.
(3,120 Views)
