Date/Time change on NILinuxRT
I need help in changing the time of my cDAQ that has the latest NILinuxRT OS.
It seem that none of the normal linux commands are working.
(1,150 Views)
You can use the NI System Configuration API. See the shipping example at <LabVIEW>/examples\nisyscfg\Get and Set Time.vi
You can run the VI on the cDAQ controller (specify the target as "localhost") or from the host PC (specify the target as the Alias name of the cDAQ controller.)
https://tmesystems.net/
(1,141 Views)
