Deploy a VI through the USB port, with a flash drive. sbRIO 9637
According to my project, I have to run a standalone VI on my sbRIO for a real time application.
In the future, i want to "update" the sbRIO by connecting a flash drive and pushing a button.
This "update" is actually replacing the running Vi by the new one on my USB flash drive and restart the sbRIO.
Is that possible ? or is FTP method the only way ?
Thank you very much.
sbRIO 9637, Labview RT & FPGA.
(2,601 Views)
Hi Max,
It is possible but it would require a bit of coding on your side.
First of all I would recommend having a look at the following page:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAM8SAO
What you could do is create a script that is being called when you need it to that does the following:
- Mount usb stick
- Check if files exist
- If exists, remove old file in startup
- If exists, copy file
- restart
*Pro tip*: You don't have to change the ini file if the names are the same.
(2,561 Views)
Thank you Natan, I'll try this solution.
(2,559 Views)
