Display sequential voltage outputs when demanded
Hi! I am working on acquiring the voltage data from a tilt sensor, connected to the board - CB-68LP and terminal 6062-E DAQCard. I need to get the voltage from output channel when I demand, write and store the first voltage to one section for further calculation, reconfigure the experimental setup and find out the second voltage for a different inclination, write and store it to another section again for calculation. I can't figure out how to do the second part as in acquiring and storing the second signal, from the same output channel when I need, without disturbing the first value. I'm new to LabVIEW, so can anyone please help me in this regard? Thanks in advance!
Message 1 of 1
(2,154 Views)
