Distributing Application For FieldPoint
I have developed an application for Fieldpoint. I want to distibute it in binary format. I want to make use of FieldPoint Explorer's Install/Remove Software feature for deploying application. Is there any documentation from NI for making Installation Scripts (*.rts)file. Or is there any other method for distributing FieldPoint applications.
(3,223 Views)
Unfortunately, National Instruments does not support the creation of custom .rts files. You may try looking through some of the existing .rts files to see if you can figure out how they work, or you can simply ftp your application to your fieldpoint units.
Greg Greenway
Applications Engineering
(3,223 Views)
