Dynamically loading a VI containing FPGA VI reference.
Hi all.
I have a program that consists of many sub-vis with different FPGA VI references. I have found that these vis consumes a lot of the CRIO’s memory.  I thought a solution to this might be to call these vis dynamically. Is this possible?
I only get error 1003 (VI is not executable), so obviously I have not been able to do this correctly. I presume that my problem is the FPGA reference as this is the only difference from other sub-vis that I have called dynamically. I tried to download the bitfile to the same folder as the VI, but I guess FPGA reference don’t know where to find this file.
Terje
Message Edited by Terje on 03-10-2008 05:24 AM
Message 1 of 1
(3,568 Views)
