ETH0 and ETH1 on SOM Dev Board (sbRIO-9651)
It appears that the xemacps 1.00a Ethernet driver does not support JumboFrames. (ethtool -i eth0).
# ifconfig eth0 mtu 9000
ifconfig: SIOCSIFMTU: Invalid argument
http://forums.xilinx.com/t5/Embedded-Development-Tools/Ethernet-XEmacPs-driver-Transmit-buffer-exhau...
Some others else getting similar performance with this driver.
Message 11 of 21
(4,478 Views)
So is it the case that even for eth1, the transfers go through the RT?
Would it be possible to stream data on eth1 using ONLY the FPGA? In my application, data would be acquired and processed in the FPGA.
Message 12 of 21
(4,408 Views)
how to enable jumbo frames? via MAX?
This would help me a LOT!
Best regrads,  and thank you
Message 13 of 21
(3,454 Views)
HI nico1981-2,
What target are you trying to enable jumbo frames for?
A Johnson
Message 14 of 21
(3,433 Views)
sbrio 9651
As far as i know, both sides of a tcpip communication need to support jumbo frames... Our PCs do that, but how to set this up for the SOM 9651???
Message 15 of 21
(3,423 Views)
Hi nico,
I've been researching your issue and based on the following article, I haven't found an official means for configuring your device for JumboFrames.
However, these targets are Linux based and thus can be configured using commands like any other Linux target as described in the following article:
Linux Configure Jumbo Frames to Boost Network Performance / Throughput
http://www.cyberciti.biz/faq/rhel-centos-debian-ubuntu-jumbo-frames-configuration/
Please keep in mind, this may not be supported by NI.
Message 16 of 21
(3,394 Views)
good morning,
is it confirmed that with eth1 or eth0 perfomance reach 80MB/S  using jumbo frames?
best regards
lm
Message 17 of 21
(2,288 Views)
The Ethernet MACs in the Zynq-7020 (the SoC used on the sbRIO-9651) do not support jumbo frames.
This is noted in the Zynq-7000 Technical Reference Manual, under section 16.1.5:
16.1.5 Notices
Jumbo Frames
Jumbo frames are not supported.
Message 18 of 21
(2,280 Views)
hi ,
did you evaluate this doc?
http://www.wiki.xilinx.com/Zynq+PL+Ethernet
br
LM
Message 19 of 21
(2,231 Views)
Hi Luca,
The document you referenced demonstrates multiple mechanisms for implementing Ethernet interfaces within the Xilinx Zynq-7000 family.  The specific implementations are on the ZC706 evaluation platform, which includes a Zynq-7045 SoC.
The specific implementations (b and d in your link) that support Jumbo frames involve implementing a soft IP for a Gigabit Ethernet controller in the PL (FPGA) of the SoC.  I don't know how large that IP is, but it appears to require hardware Gigabit Transceivers to create an SGMII interface, which are not available on the Zynq-7020 contained in the sbRIO-9651 SOM.  See Figure 4 of Xilinx XAPP 1082.
Furthermore, connecting the Linux PS drivers to the GigE soft IP would be a fairly large and disruptive change to the Zynq core (boot loader) configuration and software. I'm not an expert in the complexity of the dependencies within the complex Zynq SoC, but the AXI connections required for the GigE soft IP may also conflict with the AXI connections required for the NI infrastructure of bitfile loading, DMA FIFOs, Host Memory Buffer, and front panel (register) writing and reading.
This causes me to evaluate supporting jumbo frames on sbRIO-9651 as not-feasible.  This is not work that NI is currently planning to explore further with the sbRIO-9651 SOM.
What is the problem you are looking to solve via jumbo frames?
spex
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
Message 20 of 21
(2,222 Views)
